Speedo problem - 1999 Xantia 16v 1800
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Hi all.
I recently did a clutch change on my Xantia, the speedo has not worked since.. I have removed the 3 pin plug from gearbox and re plugged it in, in case a loose contact.. no differance.
any ideas?
there isn't a seperate fuse for it is there? was working fine before the gearbox removal..
thanks
John
AndersDK
Unread post by AndersDK »
You are on track !
Its very smart going back trying to remember what you removed/bodged during your own work - as for sure the problem originates there.
Try squeeze a wee bit the spade connectors in that plug to ensure a good contact. Also the use of a contact cleaner spray may do the trick.
Anders (DK) - '90 BX16Image
x 94
Unread post by citronut »
also look to see if the pins are coroded,if so clean them up and put some petroleum jelly on them and plug it back in,
regards malcolm
jgra1
(Donor 2021)
x 36
speedo..
thanks all..
If it wasn't the connectors tho.. could it be a fuse.. I will check them anyway.. Cant believe its the speedo head.
I have done 1500 miles this week!! so quite glad it doesnt work ;) just have to go slow for the cameras..!
John
