peu 306 td speedo,rev counter,fuel gauge
simon
Unread post by simon »
I own a 1999 306 td and the speedo,rev counter and fuel have ceased to work.All fuses are ok.Any ideas?
mg46783
Unread post by mg46783 »
Hiya,
other than a break in wiring, unlikely though, I think there should be whats called a regulator - or similar named item - usually fitted behind the dash. I think some were called Stabilizers too. That would be worth a thought. The other thing is, it could be a bulk connector at the back of the dash - ie, thae main input terminal block...be case of digging in and having a look-see.
Let us know how you get on,
cheers
mike
simon
Thanks.Problem now ok and traced to a faulty fuse/fuse connector in fusebox under steering wheel.
grattsim
Unread post by grattsim »
Any ideas on which fuse it was? Number?
