Great I think I will be following Stuarts advice and doing the following
1 Replace inline fuel filter
2 Clean and regap spark plugs
3 Undertake following suggested by Stuart
"Another thing to check is the idel stepper motor, again this controls the idel speed by sensing the vacume from the manifold. Unfortunatley it too has a tendancy to collect oil vapour. Easy calen though, as you look at th engine on the throttle body R/H side you'll see a jubilee clip one small one large undo the large one and spray some carb cleaner and then the silicone spray or WD40. Run the engine and it should clean out the motor".
Thanks Stuart, and it's still a great car to drive on big old country lanes. Highly reccomended vehicle.
