HOW DO I ADJUST THE CLUTCH!! (XANTIA)
isimo
as stated how do i adjust the clutch its a xantia activa 1996 clutch pedal is very high
RichardH
My 1997 Activa has a hydraulic clutch mechanism like the turbo diesel and the clutch pedal is quite a bit higher than the brake and accelerator. I don't think there is any form of adjustment and I got used to it quite quickly. I just wish I could move the accelerator pedal to the right a bit <img src=icon_smile_big.gif border=0 align=middle>
- x 1496
the clutch will alywas be higher than the othetr pedals I think, but.... measure the travel of the clutch pedal - it should be 150mm. If not then adjust it using the adjuster / lock nuts on the end of the cable (over the top of the gearbox somewhere - you might need to take some air piping off to get to it. Job I need to do on my TD, but haven't got round to yet!
Richard
Richard
