I noticed on many td engines a fuel connector under the bonnet which is black with 4 inputs / outputs on it. It goes in the fuel line on the return to the pump from the drain off pipes (bosch system) and between the fuel filter and the supply into the pump. I tried putting one on my zx but the car would not runn throwing out white smoke and dying after being revved to 2000rpm. When i start the car in the morning first thing it behaves in a similar fashion but is fine 1/4 mile later... - fitting this unit seemed to make the car show the symptoms i get on first start in the morning but to a greater extent.
What does this black cylindrical unit do - it seems to mix the return fuel from the injectors with fresh supply from the fuel filter.
why would mine not run with this fitted?
What is its purpose??
any i deas please
thanks
alastair
