Well just done the air filter but lost a screw and dont have any spares, Wilkobob is sure to have 1.
Fuel filter, drained the containter and replaced, bit of arsing about so i think i will just not bother draining anymore hehehe.
Ive replaced the washer jets to the new Xsara Mist Jets, not actually that difficult to do which is surprising if you take it that its me. Little electrical screwdriver used to pop 'big' clip down while rotating down and pulling (quite steardy little things to be honest), then eleccy driver to go underneath the pipe to lever off the water tight head, does a tiny bit of damage to the end of the pipe, but very minimul and its fine. Stick the news on and apply a bit of force reversing procedure and sorted...however the passenger side tends to spray the roof where the drivers side seems pretty much bang on...any ideas??
Wd-40'd the joint between the 'car' hehehe and the sphere so lets hope it helps....OH and the pollen filter!
Getting close
- x 94
mezuk04
- x 94
np
I tried to adjust the spay on mine,but buggerd it up.It came out like the old jet.Although a bit of poking around with the needle got it misting again.I just used a bit of super glue to hold them so they spray down a bit.When you`re driving along at speed,the wind force makes the spray hit the screen lower anyway.
53`406 est SE Hdi 140,110k
davehughes
np
Pug 406 jets Dave, as fitted to mine.I posted the Pug part number here,
http://www.frenchcarforum.co.uk/forum/v ... 9&start=15
davehughes
np
mezuk04
