It's been a month or so since I've posted (so appologies for not helping other people) but I need help again.
The missus has been playing bumper cars in her Mk2 Xsara, and has damaged the front bumper. It's moved down, moving the off-side headlight slightly but hasn't cracked or broken.
My questions are...
- How do I get it off
- Does anyone have any diagrams of what's behind it
- Does anyone know where I could (if needed) get a replacement.
- Does it sound expensive (the damage to the other car looked nothing so they might not claim).
Thanks in advance....
Stuart
Accident Damage - ADVICE NEEDED!
Paul Mi16
dnsey
- x 19
cosb6
What I'll do is take some pics over the weekend, and post up here. I can then guage opinion off anyone who has had anything similar.
Might be worth £200 and an insurance job.... it seems then. Her premium is only £250, so it's unlikely to rise by more than £100 or more...
As for damage undeneath, if you can't see it, I'm not bothered.
jeremy
If the bumper is ever to sit correctly all its mounts must be in the right place. Sounds obvious but its the only way to get it right. You will only really discover what has happened when you get the thing off. In the meantime its well worth having a really good look around both underneath and under the bonnet for damage which may show as actual distortion or stretched welds, dislodged sealer or flaking paint. Some cars have concertina sections in the front 'chassis' memvbers and they could absorb impact - snd so must be examined properly.
jeremy
bxbodger
Don't believe that for a minute!!! Most people seem to automatically run to the doctors and blub about 'whiplash' and 'soft tissue injuries' at the slightest little tap(the damage to the other car looked nothing so they might not claim).
And if you have even put a minor scratch on their car they are probably going to be looking for it to be fixed, that means a claim from their insurer who will be onto your insurer for the money.
In the old days, you just thumped the bumper iron straight- not so on modern cars so you really need to get the bumper off and check for damage.
The light has probably just been pushed out of its clips. (With a BX you can just pull them out by hand)just try gently pushing it back into position.
cosb6
It's the guys company car. He said he'd ask them to take a look, and see what they said. He didn't think they'd bother though... I know where I work they wouldn't if it looked ok.
Anyway, Tescos have been excellent. They've said they'll leave it 3 months, and if he's not been in touch, and we don't want to claim, we can fix it ourselves if we wish. Or if we want to claim at any time we can....
They basically advised us to get some quotes, and they'll also advise on premium rises so we can do whatever works out cheapest. The service was excellent....
Insurance Companies are getting wise to whiplash now... if the car is undamaged, then they will question it.....
zxb29
not too sure what its like on the xsara but on the ZX behind the bumper was a steel fixture or bracket which kinda bolted from the chasis onto the bumper.
When it had a knock the fixture/bracket wud tend to kink out of place and move the headlights out of position.....so u might be able to get the fixture from citroen dealer.
Jus pop down to a citroen dealer and enquire of the fittings, they have blown up diagrams on there computers so u could see how it all fits together
2005 ZX SX Diesel 64K
2004 ZX Aura TD 150k
2003 ZX Volcane TD 124k
cosb6
jeremy
cosb6
Cheers Jeremy, I'll try that..
Anyway I took of the plasic grill bit (behind the bonnet grill) and the damage is more clear to see. It's broken in half the panel that goes behind the bumper, which is why the bumper sits further back, and which is why the headlight has moved down slightly. I've looked about as much as I can (without removing the bumper) and almost certainly just this new panel will be enough in parts. The Bumper will almost certainly go back fine, although I might need to pursuade it slightly, so it's the the metal panel / cross-member that I need.
It's not the main structural one (that you can see), but one behind the bumper. It's quite thin.... anyway... that's what I'll need. Just need to get some Citroen Guru to tell me the part number... so probably a dealer trip....
jeremy
If the bit behind the bumper is meant to be a straight(ish) beam and you've got it off it may be possible to straighten it as after all its not going to be visible. It may be that if its collapsed, that sawing 2 or 3 sides allows it to be straightened - then weld plates over the cuts and paint!
jeremy
jeremy
jeremy
dnsey
- x 19
