After fitting a new gearbox and my 4-2-1 manifold, my xs has developed another problem.
I think I know what the answer is, but I would like a 2nd, 3rd or even 4th opinion...
The engine gets very hot, but the heater is ice cold and the thermostat opening doesn't help. The radiator is hot, but the bottom hose is cool. The water in the expansion tank is also cold.
I have flushed the rad and engine, so no obvious blockages, replaced the thermostat and checked the water pump. All seems OK.
I guess it is either a head/gasket problem, but there is no emulsion in the oil, it doesn't lose water and I can't see why the heater wouldn't get hot.
Anybody got any other suggestions before I whip the head off?
Cheers,
Antony
205 xs overheating problem
stevieb
Sounds like an air lock to me.
Does it have a bleed screw in one of the "higher" coolant hoses in the engine bay? If it does, try opening it up with the engine cold and see if you get a dribble of coolant. If it's dry, then you know it's definitely an air lock, and just needs bleeding.
I imagine if the air lock reaches as far as the water pump then no water will flow at all...
pugxpert
sounds like air as well,unclip coolant expansion bottle from its holder and lift it up and tie it to the bonnet.loosen brass bleed screw on thermostat housing,loosen bleed screw on heater pipe,remove cap on top of radiator on left hand side.fill through expansion bottle hanging off bonnet untill water comes clear out of all bleeders,tighten all bleeders.run up engine with expansion bottle hanging from bonnet with the cap off this will allow any trapped air to escape,run up untill fan has cut in and out then refit bottle in its holder,works everytime,same procedure on old 505's.the other thing you say you have checked water pump have you phisically taken it out? had a few where the impellor falls off inside.
EP6T petrol turbo nice engine in the 207 GT and the new mini....
macaroni
Thanks for the tips guys.
I have run it for a good 10 minutes, until it almost boiled, with both bleed screws open and only air came out. No water at all. All time, the expansion bottle was full, with cold water.
I too suspected a snapped water pump impeller and removed the pump last night and it is perfect. No play or leaks.
I think I will concentrate my next efforts on the radiator before tackling the head.
Although, the only thing that would cause the heater pipes to remain cold is an air lock, so maybe it is that! Aargh!!
pugxpert
macaroni
OK, I drained the cooling system. Hung the expansion bottle high and filled it up till rad overflowed.
I undid the bleed screws and ran the engine. After a few minutes the bleed screws starting pissing water and the heater began to get hot - Bingo I thought. Then all of a sudden, the bleed screws dried up, heater got cold and the temp gauge went sky high.
The expansion bottle filled right up and was under a lot of pressure, but the top rad hose was cold.
I have checked the thermostat, water pump and flushed the rad and the block.
It kind of points to the cylinder head, but that wouldn't explain the heater being cold.
I am perplexed! Any other ideas gratefully received.
pugxpert
i usually fill up untill water comes out of bleeders with the engine not running then close off all bleeders then run up engine with cap off expansion bottle untill fan cuts in if you run it up with cap on any trapped air in system cannot escape
macaroni
pugxpert
no not really,you can get something called a block tester which sits on your expansion bottle and you run up engine if you see bubbles and the test fluid changes colour that indicates a headgasket failure,does the car boil up if you leave cap off bottle? or is it just air being pushed out as you run it up and can you feel top hose and see if it is hot when thermostat opens? when stat opens you may find loads of air comes out then as this path is blocked untill it opens.
macaroni
The top hose does get hot when the stat opens, but if I left the top of the expansion bottle off, water would flood out. It doesn't look like it is full of bubbles, just pressure. It definitely isn't boiling up as the water is stone cold!
It really does feel like some path is blocked, but I can't fathom what. Or maybe I am just avoiding the ineviable removal of the head.
pugxpert
pugxpert
if you crank engine over with ignition coil disconected so it does not start do you see water bubbling as you crank it over? if you do its head off i'm affraid. when you ran it up with cap off did it just bubble or did it get to the point where water was spewing out of bottle?
macaroni
macaroni
