Xantia replacement CV boot strap
MickyA
I need help pulling up my boot straps! I recently replaced a CV boot on my Xantia 1.9TD but haven't been able to get the supplied straps sufficiently tight to prevent grease escaping. Is there a specialist plier available for this or does anyone know a practical workaround? The boot is standard GSF fare and has three possible tightness positions (clumsy description but hope you get my drift),- it's currently in the middle one. I could use a jubilee clip but it wouldn't fit into the recess moulded into the boot for the strap. Suggestions welcome.
M Anderson
- x 1238
MickyA
mezuk04
dnsey
- x 19
RohanC
There is a tip in the Haynes manual, which states to bend the end of a coathanger over by ~ 20mm, feed that through the hole in the boot strap and pull on the coat hanger with pliers to get the tension.
Havent tried it myself though... and i would advise caution, you dont want to slip and jab the other end of the coat hanger into your eye
Sick 200k miles black Xantia TD... Now (mostly) fixed
Now sold!
