Has anyone had experience of fitting a bike rack to a C5. I was/am looking for the type that fits on the back window area, the one I had had clips that fitted over the rear door on my old Xantia estate. But looking at the C5 the back glass goes all the way up to the roof line, not sure if its safe to put the clips around the glass.
Comments appreciated
Steve
Bike rack for C5
civvie
- x 21
bike rack for C5
Forgot to say the C5 is a hatchback
Steve
Steve
stevenlizuk
Hi Civvie,
I wouldn't recommend using the carrier if the hooks conact the glass.
I have worked in bike shops for years and have seen the damage this can inflict.
Be grateful that you don't have an AX, I've seen the bootlid ripped completely off on of those!!
I don't know if the C5 has a plastic bootlid or not but I would recommend the use of a carrier that mounts on the towball if you have one. These tend to be more expensive but hold the bikes much more securely and dont damage the car.
Look at www.pendle-bike.co.uk to get an idea of what I'm blethering about.
Cheers
Steve
Cheers
Steve
98 406 Estate LX 2.1td in white (Anyone call Ghostbusters?)
97 Xantia SX 2.1td (Chipped and happy at 130mph) Deceased after agricultural incident (crashed into field).
1981 Mini HL (Just happy to be around)
wishihadatraction
C5 bike carrier
Don't know if your C5 has a similar glass to my estate but I'd reiterate the previous advice- DO NOT put anything on the glass. I had a problem with mine not opening and a replacement was needed at over £300!! I was told that the glass was a conductor for the electrics and not any cabling. It seems very temperamental so if its working don't mess with it.
