I've done the nearside droplink, but the nut had seized onto the bottom link, so I had no choice but to drill it out (the torx socket just rounded out the hole too
). Much swearing
It's improved the handling a bit, but I still get a bit of a bomp on bad bumps, so I think pugxpert might be right about the track arm. I've got one, and I'll change it when I can bring myself to do it. At least this one shouldn't need any drilling though, as it looks nice and accessible.
One thing I noticed about the droplinks when I removed them was that the threaded lengths of the balljoints were very loose in the hub/anti-rollbar holes. I think the balljoints in the droplinks themselves were okay, it was just that the tips of the threads had compressed/squashed under use and made them a loose fit in their relevant holes. Ideally this threaded length of the balljoints should be shouldered to avoid this happening, but obviously this isn't the case.
Might be worth you taking a look at this as a possibility Quinny. Maybe one of the front bolts is moving a little in its hole. It wouldn't show up in any of the traditional ways because it'd be too tight for you to make it move by hand. Just slacken one nut or bolt at a time and see if any are loose in their holes.
