correct operating temp-xantia petrol
Post Reply
_kid_
My Cars:
Post by _kid_ »
Can anyone give advice as to what the correct engine temperature is for a 1.8 16v 1996 petrol xantia. mine says at 70c when under low load (e.g. motorway driving) and rises to around 83c before both fans operate. Is this correct?
everything else seems ok ie no coolant loss, both fans ok, heater nice and warm :) , do i need to worry?
currently no citroens :-(
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
Mandrake
My Cars:
x 666
Post by Mandrake »
70 sounds a little bit low.
My 2.0i petrol runs at 80 and the fans come on low at about 85.
There is no harm in it running a bit colder but it may use a bit more fuel. Not sure if the 1.8 is supposed to run at a lower temperature though, better wait for someone with a 1.8 to respond.
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
jeremy
My Cars:
Post by jeremy »
Sounds to me as though your thermostat has failed. This is quite important with fuel injection as one of the parameters the system measures is engine temperature.
To test start the car from cold and feel the top hose. It should remain cold until the thermostat opens then get hot very quickly. Better to measure it with a thermometer but this method will usually work.
jeremy
_kid_
My Cars:
Post by _kid_ »
thanks i will try out the test. does anyone have a 1.8 16v late 96- onwards, if so what temperature does it run at so i can be sure its the 'stat.
mandrake, my petrol consumption is a bit high. Around low to mid 20's (mpg) aroung town with lots of cold starts, and around 30mpg combined. how much would a failing stat effect mpg?
jeremy
My Cars:
Post by jeremy »
Quinton Hazell list one stat only for the 1.8 16 valve from 95 onwards - 83 degrees.
The catalogue is downloadable from the QH site.
jeremy
_kid_
My Cars:
Post by _kid_ »
jeremy wrote:Quinton Hazell list one stat only for the 1.8 16 valve from 95 onwards - 83 degrees.
So is 83 when the fans come on, or is this what the normal operating temp should be? As the fans do come at 83. The temp remains at 70, unless stop start driving where it will increase slightly.
ive 'tested' the top hose, it felt warm at around 70, and felt much warmer at 83, should this be the case?
Homer
My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever
x 16
Post by Homer »
_kid_ wrote: ive 'tested' the top hose, it felt warm at around 70, and felt much warmer at 83, should this be the case?
83 is when the thermostat opens. You should have no hot water in the top hose before that. Normal operating temperature should be a little above but the gauge won't be that accurate.
_kid_
My Cars:
Post by _kid_ »
thanks all. i'll fit a new 'stat and see how it goes, and post update.
seems like the majority of xantias are diesels :(
Mandrake
My Cars:
x 666
Post by Mandrake »
_kid_ wrote:thanks all. i'll fit a new 'stat and see how it goes, and post update.
Only in the UK :wink:
Over here, they're a novelty...
Regards,
Simon
Simon
1978 CX 2400
Post Reply
