Newbie here, hoping that I will not have too many problems that I need to resort to the site, but I must say I am impressed so far. Anyway.....
My partner has an R reg Xsara 1.4i.
It has 14 inch alloy wheels off of a Saxo VTR, with the correct size tyres.
The car has, IIRC 247 mm discs on the front. I have thought about increasing the size to 267 which is the standard size for the rest of the range, excluding the VTS. I think the sizes are correct from memory.
Anyway, I think that it is just a case of swapping over to the larger sized discs, pads, caliper and caliper carrier. And then rebleeding the system. Is it that easy
Also, can I fit the larger size discs and calipers under the Saxo 14inch alloys
As I am here, can I swap the rear drums to disc brakes easily or not.
Your guidance is much appreciated.
Spence 8)
