Hello U lot
My question is a friend of mine owns a 406 P reg 80,000 miles, and has a leak around the sunroof area. so is there any other places around it it could leak other then the sunroof it self ?
Thnks
Twiss
Pug 406 Water leak-Yes I know its a Pug
AndersDK
James.UK
If it has an aerial in the front centre of the roof, the rubber seal on that may be letting the water in. Access is under the interior roof light, it's held in place by a single nut, slacken the nut off and apply a bit of sealer between the outside rubber seal and the car roof, That may help..
But as Anders said, its more likely that the sunroof drain holes need cleaning out. There are 4 of them, one in each corner..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
