xantia heater
jcdel
xantia heater
Unread post by jcdel »
:( Help. I am stuck in Sheffield with no demister /blower/rear demister.I presume they are on the same fuse but does anyone know which fuse please.I need to drive back to East Yorks. tonight. Many thanks for any ideas or is it window fully down and rattling nuts.
liamkeen
Unread post by liamkeen »
heater blower is fuse 20 middle row 4th fuse down 20 amp
jcdel
many thanks liam. spot on. warm nuts on the way home. (And vision!)
liamkeen
has it worked or not only quoting what my handbook says
jcdel
:cry: sorry mate but appreciate your help.No/ 20 on mine(94 TD) is 30 amp.It does not look blown but that is not to say its working.I have had dry joints before.I'll get some spares when I fill up and try substitution.
I'll post when I have an answer.. Regards John
AndersDK
Unread post by AndersDK »
Its the ignition lock switch failing one of the contact sets. Standard failure on Xantiae.
There are several threads on this topic to be found if you use the forum search utility. Even a description how to fit a relay to replace the defective set of switch contact.
Anders (DK) - '90 BX16Image
liamkeen
sorry jcdel
didnt mean to send you on a wild goose chase just assumed all would be the same as my 1998 estate
sorry again and hope you sort it
i still got no central locking dam car!
Clogzz
x 40
Unread post by Clogzz »
AndersDK wrote:There are several threads on this topic. Even a description how to fit a relay.
Must be this:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17322
2002 C5 2.0i AL4 239,000 km 76372389
