C5 Emission light
silverback
C5 Emission light
Unread post by silverback »
My father in law's HPi (petrol) C5 has the service warning light on the dash come on along with the engine light.
The display on the dash also says 'anti polution' as well.
I have driven the car, and it's smooth and goes well beyond limp home speeds, although it's no-where as quick as my Xantia hdi.
Does anyone have any ideas as to what is going on?
Xantia Hdi 110
Pug 306 dts
MX5
Suzuki VL800
AndersDK
Unread post by AndersDK »
Does this C5 have the special catalysator anti-pollution additive container which can run dry ?
Anders (DK) - '90 BX16Image
406 V6
Unread post by 406 V6 »
If i recal, no, Anders, but the spark plugs need to be changed every 60.000miles or so. Could be the cat or lambda probe too :S
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
ACTIVE8
x 6
Unread post by ACTIVE8 »
Well AndersDK I have certainly encountered Peugeot's that have the container run dry.
Although the "special catalysator anti-pollution additive container" is normally on an HDI.
ACTIVA
AndersDK
Ahhh...
Back to fairly standard petrol problems then.
The C5 would have both the pre & pro cat lambda's to minimise pollution.
Could be a cable fault down there.
x 1044
Unread post by wheeler »
the HPi definitely doesent have any additive system.
It could be anything causing this,you really need to get the fault codes read.The high pressure fuel pumps are common for faiure though.
silverback
The car was taken to a local Cit man in Wolverhampton who cleared the computer memory.
The warning light is now off and everything seems fine.
He did say that the diagnostic pointed to a coil (??), and that if the light comes on again it will have to be replaced.
Thanks for the replies guys. :)
Xantia Hdi 110
Pug 306 dts
MX5
Suzuki VL800
