central locking problem
liamkeen
Unread post by liamkeen »
if anyone read my post yesterday about the problem with my car i think the stereo was tripping the central locking/clock and interior lights after fiddling with a suspect stereo there is one door not working properly when you use the RCL.
i even stripped the fuel filler cap lock out from under the wheel arch and thats working fine
but its as if the central locking is sticking
sometimes when you try using the key after the RCL stopped working you can hear the central motor but sometimes not its driving me nuts
any help welcomed cheers chaps
jeremy
Unread post by jeremy »
is this car red - its a common problem with red cars.
Seriously - give us a clue - what car is it, age, model etc all helps - particularily as there are may systems fitted.
jeremy
liamkeen
its a 1998 xantia temptation 2 estate 1.8 16v
its a real pain and i need to fix it soon
liamkeen
does anyone know if it could be a single motor broken in 1 door or is there a central unit? if so where is it located ???
davehughes
Unread post by davehughes »
There should be an electric solenoid (actuator) on each door. I know 'cos I was looking at the one on my bootlid today 'cos it's noisy. Try cleaning the elec connector or get another one from the scrappy. Maybe it was this dodgy actuator that was blowing the fuse........................
1993 Citroen Xantia 1.9 SX TD 120,000 Metallic Grey
liamkeen
any idea where they are located on each door please?
does it sound like its just one of them broken? or could it be more severe
davehughes
Remove the door panel on affected door. The actuator will be near back of door handle, joined to lock by metal rod. They are held on by two 8mm bolts on most cars (I haven't checked my Xantia yet) Piece of p*** to change
Good luck.................
liamkeen
ok doke cheers mate i think thatll be my first port of call if i do remove it the rest should still work shouldnt it?
are all models the same as i know of a L reg xantia i can take spares from
liamkeen
just been out to the car trying to fix it and all i can explain the central locking as is random sometimes boot locks sometimes it doesnt but the stereo keeps pulsing/surging and reseting itself which has got to be related to the RCL?
when i press the key fob there is clicking from the central console by the handbrake and also in the drivers door?
what can it be if its worse case scenario?
AndersDK
Unread post by AndersDK »
Worst case scenario :
Faulty earth connection under the carpeting near handbrake.
Because this means chairs and guiderails out to remove carpeting and then accessing the earth points. Center console must go out too.
Another possibility is simply a chafed cable in cable loom for the affected door. A very common problem these days on ANY car, as the makers dont think we can live without electric window winders in our cars.
Apart from that, there is one general rule of thumb you must NEVER forget :
No matter what you think you know about your car, it is ALWAYS highly likely that the problem originates from your last fiddling with your car !
Even profi mechs do it all the time !
Anders (DK) - '90 BX16Image
