i am fitting a manual box to my originally auto. i got the box from a running car that i got cheap. it comes with a clutch cable which looks like a self adjusting cable.
any idea how to install this properly? cant seem to find any info on this. only see those non adjustable ones.
Xantia petrol self adjust Clutch Cable
AndersDK
Mandrake
- x 694
Err, and you need a new brake pedal assembly too... the automatic has a MUCH wider brake pedal than a manual, and if you tried to fit a clutch there there would not be enough room or you would be forever pressing the clutch and brake together.AndersDK wrote:First of all you need a clutch pedal - which would not be there in an auto![]()
Then there is the gear lever to deal with of course.....you would need the entire gear lever mechanism including mountings which may not have come with the gearbox.
A doable project, but not as drop in and straight forward as you might suspect. There may be many snags along the way, even things like hydraulic pipes routed in such a way that puts them in the way - remember that the manual gear lever is a pivoting mechanical linkage, while the automatic gear lever is connected via bowden cable.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
magicride
