xantia air con problem?
_kid_
Unread post by _kid_ »
Hi folks and a HNY!
When my air con was regassed last year, the technician wrote on the invoice 'water valve not fully closing'. He said he got the temp down to about 10c, i have tested this by putting a thermometer (accurate) on the front center vents and the temp went down to about 8-9c, however in the summer it did not feel 'ice' cold'. Everything else air con wise seems to be ok.
So my questions are what is this water valve? Can it be repaired or it a replace only job and how much will it cost? i.e. is it worth doing.
Ive had a search through the archives and cant really see anything for the xantia, obviously its a notoriously reliable part :wink:
Many thanks
currently no citroens :-(
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
AndersDK
Re: xantia air con problem?
Unread post by AndersDK »
_kid_ wrote:Ive had a search through the archives and cant really see anything for the xantia, obviously its a notoriously reliable part :wink:
If a part is not fitted - it cant break down 8)
There is no water valve involved in the Xantia cabin heater sytem. The cabin air is controlled by flaps directing the incoming air through the heater matrix - or not.
Your mechanic may still be quite right though as the flap closing off the matrix air may not want to shut fully.
Anders (DK) - '90 BX16Image
_kid_
thanks very much Anders,
is there anything that can be done, what sort of cost will i be looking at here? or maybe DIY possibility or not?
AndersDK
Sorry - Forgot to mention that Xantia heater flaps and matrix is a very popular discussion topic on the forum. If you do a new search knowing this I'm sure you will get lots of info.
_kid_
Typed 'heater flaps' into the search engine and came up with a page of interesting problems. :roll:
From what i read when you move the temperature control slide you should hear a buzzing sound, which is what i get, so looks like they are working ok, but not fully closing from the matrix, therefore the air coming into the cabin is not ice cold.
Not much info on here on how to repair the flaps, but initially looks like the whole dash has to come out, ill have a look in Haynes for any more ideas, but looks like i will have to live with this small summer problem. :cry:
all other ideas are welcome
KevMayer
Unread post by KevMayer »
Could your temp control unit be faulty/worn.
I know my temp selector seems to go out of adjustment from time to time. I seem to get it working if I slide it from max to min several times. Its as though there is a rehostat inside which gets slightly oxidised. Sliding it vigorously back and forward seems to clean it up and then I get more precise control.
One change I've noticed lately is that if its set on auto and I slide the temp selector to min or max I don't get full fan speed. When I first had the Xantia selecting min temp would bring the fan on at full speed and blast cold air. Selecting max would bring the fan on full speed blowing hot air. Now I don't get full fan speed unless I select it to full speed manually.
Maybe the temp you select is not being realised by the heating system so when you select min/cold the system thinks you selected 'slightly cold' and hence the flaps stay slightly open letting some warm air through.
Cheers,
Kev
Cheers, Kev
_kid_
KevMayer wrote:Could your temp control unit be faulty/worn.
Cheers,
Kev
Thanks for that, interesting stuff. The fan does go to max (and loud) speed when the temperature control slider is set to the min or max settings so looks like this is ok. I have read on the honestjohn website a few small fords (ka and fiesta types) that moving the temp control has the effect you are describing. I will give this a try. Is it best when the engine has started or shut, and how often is this recommended.
Cheers
KevMayer
Probably best done when the engine is warm so you'll feel the effect if anything changes.
Cheers,
Kev
Cheers, Kev
Mandrake
x 694
Unread post by Mandrake »
KevMayer wrote:One change I've noticed lately is that if its set on auto and I slide the temp selector to min or max I don't get full fan speed. When I first had the Xantia selecting min temp would bring the fan on at full speed and blast cold air. Selecting max would bring the fan on full speed blowing hot air. Now I don't get full fan speed unless I select it to full speed manually.
Mine has always been like that, and I'm pretty sure the one in Dad's car does the same, I thought that was normal ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
alan s
RIP 2010
x 6
Unread post by alan s »
It is possible that he may mean the "TX Valve" which stands for thermostatic expansion valve which is associated with the actual control pf the refrigerant in the system, the idea being that it lets gas through until the frost line is the full length of the evaporator at which point it cuts the supply of refrigerant and it is possible to have these not close off and to "flood" the system which will reduce the ability of the air con to col as cold as it shouldl as it will be unable to pump the back pressure down far enough.
The cause is usually due to the system being overcharged with gas, so I'd suggest if this character thinks a TX valve has anything to do with water that you try a different repairer, because my bet is he overcharged it with gas and hasn't a clue what's gone wrong or he is well aware and is going to take you to the cleaners fixing it.
Alan S :wink:
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
davehughes
Unread post by davehughes »
Going back to the oxidised rheostat; if you can get access to it, ie remove centre panel over heater controls (easy)you want to try spraying 'Switchlube' into the switch/rheostat I've used it loads of times and it's the bollocks. When it's cleaned out the switch it evaporates. I've used it on things like indicator stalk switches and that sort of think and it can save a fortune
1993 Citroen Xantia 1.9 SX TD 120,000 Metallic Grey
fridgedoc
a/c
Unread post by fridgedoc »
Hi Kid
Did you get your a/c sorted?
Where in the uk are you?
I'm in Croydon, could have a look at your a/c if you are near.
Let me know
Bonne Chance
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
_kid_
Hi
No, im waiting till summer and see how it is then
Unfortunately im in Leicester!
fridgedoc
A/C
Hi Kid
OK mate sounds like it is slightly short of refrigerant
Bonne Chance
Stephen
alan s
RIP 2010
x 6
Looks like I've learnt nothing in 50 years. :roll: :wink:
Alan S :lol:
RIP Sept 19th 2008.
