Xsara heater problem
thenig
Unread post by thenig »
Hi, i have a 2000 xsara hdi. not air con. the problem is that the heater will only blow on the 4th setting but not the rest. I have changed the 3 spring and resistor component, and it worked for a few days but it went again. I would be greatful for any suggestions regarding solving this problem.
mezuk04
Unread post by mezuk04 »
whats the chances of fitting new resistors but with a bigger voltage (or whatever the term is) so they can handle more current?
Volkswagen Golf 59' 1.6TD S :(
Clogzz
x 40
Unread post by Clogzz »
Does the car have a pollen filter ?
If yes, a blocked filter will cause high current that will strain the resistors.
2002 C5 2.0i AL4 239,000 km 76372389
Stuart McB
Unread post by Stuart McB »
Check for debries if all fails in the motor housing. easy job on the Xsara. Foot well carpet back, undo screws and hey presto out she comes.
The wifes got a C4 I've got a ZX TD SX!!!!
