Hi mates, my 95' 1.4 zx avantage can't start, when you switch the key to start the car can't start and i can hear a sound like a fan coming out the engine(not clicks, nothing,just like a fan rotating), and on the 5 or 6 try, the engine start, what could it be?the starter is ok, it is rebuilt with its solenoid, i started to look for a ignition relay and this car doesn't use it, please,any help would be appreciated.
thanks again
zx can't start
AndersDK
- x 94
it might be that the starter is spinning and not beeing throne into mesh with the flywheel ring gear,or the ring gear teeth are worn away where the starter should engadge with it,you can test for this by putting the car in gear and move the car forward a little bit with the ignition switched off,this will rotate the flywheel to a point where there is good teeth,then try to start the car,if this works then you need a good second hand flywheel fitted or a new ring gear fitted
regards malcolm
regards malcolm
victor xt
thanks andersdk and citronut, the battery is good,the voltage and the load test is just fine, it's not the starter, it is good too, i think it could be a possibly faulted ignition switch, if so, where is it located? or is the ignition lock? where you put your key to switch this? sorry for my english but i don't know the technical word.
by the way........... happy new year !!!!!!!!!!
chemexhants
Starter switch is at the base of the ignition barrel. To prove whether the problem lies here use a short length of cable to short across the terminals on the starter motor - please ensure the car is not in gear before trying this! (obvious, I know, but I once saw a 'mechanic' pinned against a wall when he got it wrong).
Stephen
Stephen
1997 ZX SX 1.9TD 140k miles
jeremy
I've got a similar problem with our 1.9D. Wouldn't re-start one morning when we were out in it - key turned but nothing at all seemed to happen. When we tried the light test the lights got BRIGHTER when the starter was operated!
To me the lights getting brighter suggests that the glow plug timer/relay cuts the power to the glow plugs - and meant that the ignition switch was working - as something happpened every time.
I tested the supply to the starter solenoid with a test lamp but while doing this the thing started - so I drove it home without any problem.
Subsequent testing suggests that there is a problem with the supply to the starter solenoid - not the heavy battery lead but the small one from the ignition switch.
There is a large multi-plug located by the nearside strut in the inner wing and certainly on the 1.9D it is inside a black plastic box. To get at it you have to undo/lift out the plate holding the relays/fuses and you will then see it - its rather superior and round with a screw securing ring. I believe the fault on our car is in there and separated the plug which seemed to be immaculate with one slightly dirty terminal. I cleaned it with switch cleaner and scratched the one dirty bit and all seemes much better but it still sometimes doesn't connect properly. I had to remove 2 plastic nuts in the bottom of the black box to loosen it to get my hand in.
As an emergency bodge - jump the starter. Put one end of the wire on the large terminal (battery +) and the other on the small terminal and the starter should spring into life at any time regardless of the position of the ignition switch. If this works you know the starter motor is working!
jeremy
jeremy
jeremy
victor xt
Hi, thanks for replies, i measured the starter and its solenoid and when my friend put the ignition switch at the start position, the sound was coming out directly from the solenoid,like it was stuck and sound like accumulating current, the voltage drop was about 1.3 volt more or less from 12.63 to 11,20.
So, what do you guys think then?
Cheers
Cheers
zxTd
victor xt
thanks for that, the weird thing is that the battery is ok,when i start the car it shows a voltage like 10 volts, not less of 9 volts, so, the load test is ok, and the alternator gives a 13 to 14.3 volts at idle and light on, my problem is almost happening all the time,at the 5 or 6 try, the car starts with no problem at all, a couple of months ago, this was happened soemtimes, this car is driving me crazy
after spending a US $1800 in spare parts,new clutch, new front suspension (sasic),new engine,and other stuff to name one of that.
Clogzz
- x 40
victor xt
jeremy
- x 1238
victor xt
