Xantia Activa Spark Plugs.
Quackers
x 17
Unread post by Quackers »
How many MM should the gap be on the spark plugs for the 2.0 Turbo CT?
Peter Mannn
Unread post by Peter Mannn »
Dunno. What I do remember is that both times I pulled the sparkplugs there was zero wear. From now on, they stay in until she gets hard to start when cold, which is the telltale of excessive spark gap.
zxTd
Unread post by zxTd »
depends on what plugs you have in it, all recommended plugs are 0.9mm apart from Bosch which is 0.8mm ( information based on a 1995 motor )
x 1238
Unread post by Peter.N. »
In the distant past when I ran petrol engines (they had carburetters then) I didn't touch the plugs unless starting became difficult, then I took them out, cleaned them and closed the gaps up until they were about the thickness of your thumbnail, that always used to cure it.
macaroni
Unread post by macaroni »
Activa spark plugs are special ones that require no adjustment of the gap.
zxTd
xantia activa :?:
is the car model surely, never heard of a spark plug called an activa :idea:
