My present Xantia's had its speaker wiring butchered to bits with bare ended wires and missing speaker plug.
Fortunately I have another plug from the Xantia I'm breaking, but does anyone have a pinout of the 8 speaker terminals on the back of a Xantia radio?
Xantia radio speaker wiring
AndersDK
These days car radios have standardised connections :
Try if these colours apply to your radio (from an earlier Fisher radio) :
4 speaker system
white+ & white/black- to front left speaker
green+ & green/black- to rear left speaker
gray+ & gray/gray/black- to front right speaker
violet+ & violet/black- to rear right speaker
(i.e. colour+ means this colour wire carries the speaker plus signal - and colour/colour- means this wire carries the same speaker minus signal)
4 speaker system
Anders (DK) - '90 BX16Image
D.Slatford
Unfortunately that doesn't help. In the car I have a bunch of mostly green and brown wires with bare ends. I can figure out through trial and error how they pair by just by putting a multimeter or similar methodically across them and listening for which speaker clicks! There's more than four pairs, so presumably there's two pairs for the tweeters in parallel with the fronts.
I have the missing 8 way connector from another car with different coloured wires attached. All I need to know is which pins on this connector corrosond with which speakers.
I don't know how they're mean to be numbered, but consider the ASCII art, which pin is which?
Code: Select all
|[1] [2] [3] [4]|
|[5] [6] [7] [8]|
Dave Burns
D.Slatford
