Xantia brakes
bernardo
Xantia brakes
rear brakes on Xantia wont work. car failed mot . bleed screw opened very little pressure. anyone any ideas. 1996 19d turbo estate
406 V6
Any HP Citroën rear brakes only "work" efectivelly with some weight on the rear of the car, as they are dependant of the load on the suspension. Load the boot with a sac of cement next time
(any other thing thats weights is good too)
To have them bled, put the suspension on maximum height and then do the procedure.
How's the rest of the hydraulics? Is the accumulator sphere good (ticking intervals longer than the minimum of 30s)?
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
- x 94
Homer
- x 16
Re: Xantia brakes
If you have opened the bleed screw with the suspension on anything but maximum and the car suspended then there will be very little pressure.bernardo wrote:bleed screw opened very little pressure.
The rear brake pistons of BXs and Xantias are prone to siezing because they are so rarely used. You will probably get them back in operation simply by removing the pads and pushing the pistons back. There is a chance the seals will get damaged when you do but they are pretty easy to fit.
fastandfurryous
- x 4
406 V6
Exactly, that's what i meant! For MOT, put some load on the boot, to bleed it put it on max for system pressure.
Ah Xantias, at least they don't eat rear pads as fast as the front like the C5...
Francisco
