Demister partially working?
tonyb1
Hi guys. I'm having a bit of trouble with my back window demister this year. Only certain areas of it are demisting. Some parts of it don't clear, like some of the lines across the window don't clear, and some do, Is there an easy fix for this apart from changing the window? Thanks.
Xantia 1.9 TD LX 1994 - 152,000 miles and running, strange vibrations
bxbodger
Go to your local spares shop and get some electro-conductive silver paint which exists for just this purpose-then just check each non-working line in turn for breaks and paint them over- don't use the useless template that comes with the paint:use 2 bits of masking tape very close together.
My bottle was made by Granville, who do the copper grease, etc, and it works very well!!!!!
- x 94
bxbodger is corect except for the maskingtape,i find that selotape or any tape with a smooth edge is best other wise you end up with a furry edge,also you should not put this paint on in exsses,just use it in moderation and just the point where its needed,as to much or to thick can explode your screen,because it alters the resistence
regards malcolm
regards malcolm
tonyb1
jeremy
- x 1238
