I have tried in vain to stop the cam cover weeping oil on my ZX 1.9TD.
Im on my second rubber gasket now in 3k miles i couldn't stop the first one leaking so tightened the 3 bolts just a little past there torque settings and cracked the cover.....AT THIS STAGE I WEEPED
Down to local breakers for a replacement cover,fit another new gasket but still she weeps oil.
Does anyone have any tips on setting the gasket with just those 3 bolts or do all XUD covers leak ?
Many thanks
ZX with a Weeping Cam Cover
citroenbx
Life feels good just as you complete No4 Glow Plug on a ZX-TD
Stuart McB
AndersDK
Try if the seal surface on the cover is still true. If the bolts have been torqued the cover have a tendency to twist.
Easy checked on a level table top. You may even see it looking down the seal surface.
The solution is to carefully bend back the cover - overdoing it a wee bit the opposite way - i.e. make the cover wee narrower midway.
Anders (DK) - '90 BX16Image
jeremy
XUD's don't seem to be endemic leakers anywhere as far as I can see. Neither our BX TD (200000 miles) or ZX 1.9D (77,000 miles) seem to leak from cam cover - but I did have a leak from there on the ZX which turned out to be one of the cover bolts had worked loose!
The do leak from elsewhere - like the breather tubes, cam seals, and I suppose with a Roto-diesel a perished leak-off tube would put oil in this area - especially when the car was driven fast. (Bosch would give bad starting with defective leak-off tubes)
jeremy
citroenbx
Thanks guys so far..........My engine doesn't leak anywhere but here.
I'll take the cover off next week and just double check its true.
Yes your right about the the 3 bolts and the cover moving.I have been very carefull fitting it back and making sure everythings square.
I even bought 3 new Carbon washers for the 3 bolts just to be sure,but no oil still creeps under the rubber ?
Cheers for now anyway.
- x 94
np
My cover started to leak oil about 3 yrs ago.I brought a new gasket from a local factors & fitted it.After a week it was leaking worse than before.Took it all apart & back together again but still leaked.Brought another gasket from another factors,same again.Still leaked
.Went to Citroen,got a gasket from there,fitted it the same as the otheres,no more leaks
.Still no leaks after 3 odd yrs.Dont know if the other gaskets were badly made or over size or what.But the Citroen gasket cured it.
53`406 est SE Hdi 140,110k
G4EIY
The method that I use is as follows:
Take off the cam cover, and place it on a flat surface (I use an oven door glass)..
You will note that there are several projections which limit how much the gasket is compressed, and these should all be level.
If the cover has been over tightened in the past this will distort the cover, and will show on some of the projections being higher or lower than others.
Remidy: place a sheet of course wet and dry paper on the glass, soak with diesel and gently rub the cover over the paper till all the projections are shiny. You may require an assistant to hold the paper in place.
Refit the cover and with luck, no more leaks.
Brian - 86 Visa 17D Sorn(192K)/ 86 BX 17RD (220K) Scrapped/ 92 BX 17TZD Turbo Diesel (191K)
96 306 XRDT (174K)
96 306 XRDT (174K)
citroenbx
wilkobob
