could anybody please tell me how to remove ecu from xantia diesel located on fuel pump as i need to replace due to lost immobiliser code
bigboy
xantia ecu removal
Dave Burns
- x 3
Bad news I'm affraid, the pump has to be removed from the engine, then the shear head bolts that hold the steel (gold coloured) security cover on have to be driven round (unscrewed) by punching them with a hammer and a punch, that is the most common method, or if that doesn't work they have to be drilled out.
It is impossible to do this with the pump in place and the pump is a bit of a bugger to get off, you need an "S" shape spanner or a crescent spanner to get at the bottom nut on the pump mounting flange, if its an aircon model that is as the hydraulic pump is then mounted high up making access to the bottom fuel pump flange nut difficult.
Dave
Dave
bigboy
RichardH
You may be able to get the keypad immobiliser read or reset. Some auto electricians have the gear to do this. Check out http://www.unimark.freeserve.co.uk/serv03.htm or do a web search on "keypad immobiliser" and see if you can find someone close to you.
Good luck, Richard
Good luck, Richard
bigboy
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
Good luck, Richard
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>yes thanks i had looked at that option but have a conflict of interests citroen say that the code is only in the ecu not the key pad various companys that claim to read require the keypad and ecu to be sent the ecu is fixed to the derv pump via shear bolts if you could get it off without knackering it it will cost £85 to decode a bit of a gamble i thought when citroen sell new ecu fof £90 and ther are a few out there who claim to be able to get the code via the pad only for £70 again do you risk it?
bigboy
Edited by - bigboy on 19 Nov 2002 10:12:30
Edited by - bigboy on 19 Nov 2002 10:34:11
Good luck, Richard
bigboy
