High Pressure Fuel Pump
pikecrazy
Unread post by pikecrazy »
I've been told today that the High Pressure Fuel Pump has failed :evil:
Can these be repaired :?:
If not how much am i looking at for a new one :?:
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
pugxpert
Unread post by pugxpert »
contact your local bosch agent they may be able to overhaul it :?:
howiedean
Unread post by howiedean »
pugxpert wrote:contact your local bosch agent they may be able to overhaul it :?:
I'd have it checked and then get a quote just to make sure it is the pump!!! I'd also price one up from a scappy as there should be loads around for your model.
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
drpau
Unread post by drpau »
Sheeeet :( that sounds expensive. Has it just gone all of a sudden with no warning or were there any strange noises etc prior to it going kaput? I notice you have had some engine management lights come of before, Im guessing this is all down to the pump failure?
99 Xsara SX HDi 105k with PSi power box- smokier but well worth the wonga!
pikecrazy
drpau wrote:Sheeeet :( that sounds expensive. Has it just gone all of a sudden with no warning or were there any strange noises etc prior to it going kaput? I notice you have had some engine management lights come of before, Im guessing this is all down to the pump failure?
No warning or noises , the engine management light came on but didn't register a fault.
Have sent details to get a secondhand pump off Breaker link fingers crossed . Apparently there like rocking horse poo :?:
If i don't get a reply its off to the Bosch specialist for a refurb or a new pump :evil:
AndersDK
Unread post by AndersDK »
Seems to be a bad habit for HDI pumps. You're defo not the first to face this lemon ... :roll:
And yes they fail w/o warning. Engine simply dies for good because of missing fuel.
Anders (DK) - '90 BX16Image
