Changing foglight
silvershadow21
Changing foglight
Unread post by silvershadow21 »
Hi everybody
hope this is not to trivial.
I have a Renault laguna sport 1.8 16v-- Year 2000 on a X plate
One of the front foglights has went out on the front spoiler at the drivers end, and i am buggered if i know how to get into it, to get it changed. I managed today to get the bulb removed from under the bonnet, but cannot manouver the replacement in , and also cant get it back into the casing to secure the clip, cause there is almost no space at all.
Whats the easiest way to do this type of job
Is it from underneath ?
Or does the foglight itself, come out from the front at all
cheers
tom
TazzyK
Unread post by TazzyK »
on mine (97 P) you have to take the whole fog light out...should be the same for yours...it is the same on almost all cars with fog lights. There is probably a cover of some sort around / next to the fog lamp which has to be removed to allow you to see and remove the screws to the fog light
