BX power steering
ianselva
BX power steering
Unread post by ianselva »
HELP!
my 1992 BX TZD has a problem with the power steering . The assistance keeps varying ,one minute the steering is V light ,next quite heavy. I have had the fluids and filter changed , tightened up the drive belt. The brakes and suspension are fine. It seems worse when it is all cold , fairly minimal effects when it all gets up to normal temperatures.
jeremy
Unread post by jeremy »
You need a new pump! PAS takes a high volume - and so while the pump will raise the car etc it does not supply sufficient volume for the PAS.
jeremy
fastandfurryous
x 4
Surely this could also be a sticky FDV? well worth changing that for a known good one (are they dismantaleable?) before condemning the pump.
This is not a signature.
mezuk04
Unread post by mezuk04 »
Hey Ian,
Nice to see you aboard! 8)
Volkswagen Golf 59' 1.6TD S :(
ianselva
FDV ?
Fluid ? Valve ???????????????
and whee will I find it ?
ACTIVE8
x 6
Unread post by ACTIVE8 »
FDV means Flow Distribution Valve
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I tried three known "good" pumps on my BX trying to improve things , then in desperation I went to GSF and bought a recon one, exactly the same :oops: If you need one to try I have a spare PM me.
Stewart
