306 HDI starting
saxocar
306 HDI starting
Neighbour has an N reg, 306 HDI which is difficult to start, but once started runs normally. A garage has checked the glow plugs battery etc (not sure what the etc is exactly) and can find nothing wrong. Suggests the pump and estimates £600 fitted. Question is can it run normally if the pump is faulty?
PowerLee
saxocar
fastandfurryous
- x 4
Sounds very much like an air-leak into the fuel system, and that the Garage is either completely inept, or going for a fairly good rip-off. Nothing new there then.
Check fuel lines (including leak-off pipes) for splits, cracks, loose connections etc.
Try pumping the fuel primer before starting the car. If the starting is improved, you have your problem.
This is not a signature.
