Hello,
Advise needed please. My 97 VSX Xantia is rattling more than ever - new water pump, air con bearing and belt fitted but engine clattering more than usual (positively deafening compared to my C5 HDI). All comments/suggestions welcome!!
Regards,
John.
XANTIA 1.9TD RATTLE
johnway
XANTIA 1.9TD RATTLE
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
mezuk04
johnway
XANTIA 1.9TD RATTLE
The rattling is from the offside engine when at low revs/startup - the faster the engine speed the less rattle. I know diesels clank at the best of times but this really sounds like a bucket of bolts.
Regards,
John.
Regards,
John.
mezuk04
- x 94
fastandfurryous
- x 4
- x 1238
If its diesel knock through over advanced timing, it will get quieter as it warms up, if its a mechanical knock, I would check the crankshaft pulley for tightness, the key can wear and allow it to move even if the bolt is tight. If you can get to it, you should be able to feel it move if thats the problem, unless of course you have allready checked that and I've missed something.
AndersDK
john alexander
BrianM
johnway
XANTIA 1.9TD RATTLE
Thanks for all the advice, guys! On further examination I have determined that the majority of the rattling is at the top of the engine. Pulley OK, could the diesel pump be the culprit or ?
Regards,
John.
Regards,
John.
Kowalski
johnway
XANTIA 1.9TD RATTLE
Right,
A change of filter it is this weekend (about time it was done too!!)
Regards,
John.
Regards,
John.
