Is My Turbocharger on its way out ??
steviewonder7
Unread post by steviewonder7 »
Hi Folks,
I dont know if this is a problem or not,but I dont like the look of it.
Today upon renewing my alternator/steering pump auxillary ribbed belt I was looking about the rest of the engine bay as you do and found something that maybe a sign of something going to fail in the near future.
What i found was some engine oil that over a considerable period of time seems have been weeping from the intercooler pipe where it it connects to the intercooler.This appears to be on the 'compressor to intercooler' side of the turbo,which seems to me to indicate perhaps(please,please tell me if I'm wrong of course) that the compressor side turbo bearings are letting oil by.
Now ther'e no other signs from the turbo that anything is wrong.The car pulls strongly as I believe it should do for this car.The car doesn't drink excessive ammounts of oil at all.
Am I looking at obtaining another turbocharger :cry:
Is there some sort of pressure/leak by test that I maybe able to to to prove anything?
Much appreciated for any help on this issue.Thanks Steve :cry:
1994 Xantia 1.9TD sx non anti sink.No aircon.Gone to the great scappy up above.
Now with Xsara Picasso 2.0 HDI (90 bhp)(03 plate) in 'Wicked Red'
AndersDK
Unread post by AndersDK »
Dont think it's that bad.
All recent modern cars I've fiddled with are quite dirty with oil on the intake side. This is because of pollution regulations where oil fumes must be lead into the engine combustion to reduce pollution.
Result is often dripping oil from dismantled air intake components. Things gets worse as some of the fume hoses has a tendency to clogg with mayonnaise and then oil mist may very well reach the intake.
A dead turbo will tell you when time comes. And it will be either CLOUDS of white smoke from vapourised engine (i.e. turbo seal) oil into the exhaust on the hot side.
Or a very gutless engine.
Anders (DK) - '90 BX16Image
nick
Unread post by nick »
"They all do that sir" :lol:
If there's no other problems I wouldn't worry. My current Xantia was doing this slightly when I bought it five & a half years ago - its still doing it now & its never got any worse.
x 1238
Unread post by Peter.N. »
I would concur with the above, the turbo shaft seal is more likely to go on the exhaust side producing clouds of blue smoke. There is always some oil mist present in the air intake as explained above but this can increase considerably as the engine starts to wear so with the mileage that most diesels of that age have covered its inevitable.
steviewonder7
O.K ,so its not as bad as it seems then.Thanks for your replies.
Steve
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I kept finding oil in the intercooler pipes, leaking from the inlet manifold, obviously coming from the turbo?? but its no indication of wear, they really do "All do that"
Stewart
