HELP!!!!!!!!!!xantia keypad immobiliser
bigboy
Unread post by bigboy »
i have just become the proud owner of a xantia sxtd i wanted to change the immobiliser code(for obvious reasons) and did so following the handbook unfortunately being a techno freak somewhere along the processw i have entered a number wich i cannot remember every time i tried i got red and green lights together which the book says code error or fault as it was working perfectly before my hideous attempt to change it i am sticking with the fact i dont no what code i entered any suggestions on getting the code dont fancy buying new ecu and keypad.where is the ecu located and what does it look like? thanks
bigboy
Edited by - bigboy on 18 Nov 2002 09:15:49
MW
Unread post by MW »
First, don't do anything in a hurry. As you've probably found out by now, entering the wrong number more than a couple of times will lock up your security system for a certain period - doing it again will make it longer and longer.
I remember that when I bought my new Xantia (first of August 1995, first day of the new registration letter, etc), my local Citroen dealer had received a couple of Xantias with the wrong start codes. Not even the dealer was able to get them started in time for the eager new first-day customers to drive them away. Very embarrassing!
Take a long cigarette break, take a walk, and try to de-stress. Apart from hypnosis, it's your best chance of remembering the number.
Mike
