Hi all
Ok i need 2 new ABS sensors front left and rear right (from sitting inside the car).
There is a Xantia in the breakers yard which i have been raiding, it also has the sensors i need, what are my chances of removing these sensors with out breaking them? and also any tips on this procedure would be most helpfull.
Thanks in advance
Tony
Removing Xantia ABS Sensors (with out breaking them)
Nomad
Xantia 1.8i 8v Presige 1995 Left Hand Drive, 5 door hatchback
pugxpert
JohnT
Nomad
Thanks for the replys guys
Bloody hell, they are expensive for what they are
Rear = 56.50
Front = 68.50
Total 125.oo + VAT
Unless i am looking in the wrong place on GSF site.
I think i will have ago at getting them out of the car in the breakers yard first, i have nothing to loose.
What tools do i need to take with me, to make the job nice and easy? also any advice on how they come out.
Many Thanks
Tony
Rear = 56.50
Front = 68.50
Total 125.oo + VAT
Many Thanks
Tony
rossnunn
- x 94
its not usualy the sensor itself that gives up,its normaly the cable that fractures where it is flexed on the rear where susp arm pivots and fronts where the susp leg rotates every time you turn the steering,a tv engineer freind of mine has repared them on a 405,he located the break in the cable cut it open rejoined it bobs your aunty dodahs your uncle
regards malcolm
regards malcolm
Nomad
JohnT
- x 94
samtronic
You can find a bit about it in this thread:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=14392
The site mentioned in my post has moved:
http://81.216.240.206/citroen/XANTIA/fels_abs.html
By the way, it is not allways the cable that fails; on my front ABS sensor the core of the sensor had corroded and expanded the plastic bobbin enough to break the very thin wire inside the sensor. Just like described (in swedish) here:
http://81.216.240.206/citroen/XANTIA/rep_av_abs.html
The fix was to open the sensor, unwind the wire, fix the bobbin, rewind the wire and seal the sensor using epoxy. I did that more than half a year ago and it is still working fine.
Søren
Søren
'93 Xantia 1.8i 8V
- x 94
Nomad
Ok here is an update on this.
I went to the breakers yard this morning to get the sensors from the car, i was there yesterday to soak them all in WD-40.
Bearing in mind my car is a left hand drive.
The front drivers side was already damaged This was where the car has had a big crash.
The 2 rear ones were imposiible to get out with out breaking them (all work was done from a ladder as the car is sitting 2 meters up on a shelving system), i did try to ease them out nice and slowly then the black plastic surround broke away
The only one i got with no damage was the front passenger side.
I need the front drivers side
Now are the sensors on the front the same? or are they handed?
Looking on the GSF website it just says Front and rear.
If they are the same and providing it works i have saved my self 60 odd quid, i only paid 1.50 for the sensor
Thanks for your help on this.
Tony
Tony
samtronic
As far as I can tell, right and left sensors are identical, but according to the local price list I've got, the front sensors come in three variants (->7/94, 7/94-11/97 and 11/97->) and the rear sensors come in two variants (->11/97 and 11/97->).
I don't think there are much difference electrically and if you can get it to fit with the same gap between cog and sensor as before, it should work fine.
Søren.
Søren.
'93 Xantia 1.8i 8V
Stewart(oily)
- x 35
I think folks here end up replacing the co-axial cable then sealing it all up with heatshrink, I tried to remove sensors too, they are just too fragile.
Stewart
Stewart
Nomad
