AndersDK wrote:There are other possible reasons to fast ticking pressure regulators than a flat acc sphere.
But a flat acc sphere is by far the most common reason. And by far the cheapest and easiest first option.
The PR itself may leak in the feed valve to the acc sphere.
The brake doseur valve may leak.
One of the suspension cylinders may leak.
One of the HC's may leak.
Anders, add to this list the hydractive control blocks, as these seem to be a BIG source of pressure leakage in some cars, far exceeding any of the other sources you mentioned.
I didnt mention it until now because the OP's car isn't a Hydractive 2, but it bears mentioning for anyone else following the thread.
On my car with a perfectly normal accumulator that tests 62 bars, the regulator is currently cycling every 18 seconds, but if I disconnect/disable the hydractive valves by unplugging them or removing the hydractive computer fuse, the regulator cycle time increases to 3 minutes 45 seconds.
Listening next to the valve with the engine off but the valve activated there is audible hissing indicating leakage.
I've had confirmation from at least one other person that their car does the same thing, so I don't think its an isolated case. I'll be taking one of the valves apart soon anyway to tweak the damper valves so I'll see if I can find what the source of leakage is. My guess is either particulate grit stuck in the seat of the needle valve, or a failed o-ring.
So in summary, anyone doing the regulator cycle time test for an accumulator on a Hydractive (2) car ought to disable the solenoids during the test or you might get a false "fail" of the accumulator.
Regards,
Simon
