Hi
Can anyone tell me if the changeout of the Xantia Hdi low pressure fuel pump and sender unit in the tank is a DIY proposition at all. My one has started to make a noise fairly regularly now and I think it might be wise to change it before too long. However my local garage has quoted me around £270 parts and labour which is a bit dear for me at this time of year so I wondered how difficult a job it really is. Can anyone help?
Dave
Xantia HDi Low pressure fuel pump
mcgregor
- x 1432
I think you can do it from inside the car - lift the rear seats, and pull the carpet out (on the N/S I think). There should then be a big black blanking plug there somewhere, pull that out, and you should be able to see the pump on top of the tank. I'm pretty sure you can get the pump out through the hole in the floor - just take care not to fill the inside of the car with diesel!
mcgregor
- x 1432
