C5 2.0i Gearbox Jerking
EricH
Unread post by EricH »
The gearbox of my 2001 C5 2.0i Petrol has been acting strangely. Sometimes, when stopping at traffic light, the car would not move even though I have released the brake and the gear indicator is on D. Upon pressing the accelerator, the car would jerk once before moving. Anyone encounters similar problem? Help appreciated.
406 V6
Unread post by 406 V6 »
How does it behave in sequential mode?
Sounds like an adjustment on the cable is needed or the fluid level checked.
cheers!
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
EricH
It behaves the same with sequential mode. The gearbox oil has been changed not long ago and proxio diagnosis revealed no problems with the gearbox at all. Are you referring to the brake cable? Thanks.
406 V6
i'm refering to the selector cable. It could need to be adjusted if, for instance, the gearbox selector would not put the gearbox in the exact position, i.e., instead of "D" it would be 5mm from that position and when the car revs it "slips" the 5mm and engages D.
P, N and R engage ok?
Francisco
dnsey
x 19
Unread post by dnsey »
Are you certain that the correct fluid was used?
EricH
Thanks chaps! P, N & R engage ok. AL4 transmission fluid was used. I am just wondering whether the problem has anything to do with solenoid valves.
