I changed my front spheres at the weekend no problem. Moved onto the rears - suspension on high, clamped the tool on and tried to turn one of the spheres a bit before depressurising. The sphere turned all right - but so did whatever it is screwed into (ie the hydraulic pipework rotated with the sphere, and no, I wasn't undoing the anti sink sphere by mistake)!
What am I doing wrong?
Xantia rear spheres
- x 1238
Short answer - nothing. The sphere is obviously very tight. I can only suggest that you attack it with a cold chisel and heavy hammer. Put the chisel on the seam around the middle at as shallow an angle that will allow it to grip and give it a good hard clout, anti clockwise, the shock should loosen it, several applications may be necessary.
splat2
Ok, I've done what I should have done before posting and searched. It appears the standard technique to get round this problem is to load the entire family into the boot to increase the pressure.
I'd really rather not start hitting things with a hammer and chisel as my success rate with such techniques is quite low, usually resulting in broken car and/or broken me.
'97 Xantia TD 170k
JohnT
The system must be under full pressure at its maximum hight to stop the brake valve rotating. I then jack up the car (with stands) and leave the engine running. Then use your removal tool, the brake valve should stay put and the sphere will release. I have sometimes used a long jack handle when they are really stuck.
Cheers!
John
John
Stewart(oily)
- x 35
Family in the boot is the tried and tested
back end up on ramps, any height setting apart from the lowest really you need weight in there to prevent the susp cylinder from turning or you will be down the dealer buying pipes, once the spheres have cracked you need to lower the car onto its stops then its simply a matter of unscrewing the old ones, the o rings should be fitted into the register in the cylinder end, screw the new spheres on hand tight
If the spheres are still tight then the hammer and chisel method does work, theres a ridge around the "equator" of the sphere, make a start there and give it a few good bangs
Stewart
Stewart
