FRONT SEAT REMOVAL
WELSHVIKING
x 4
FRONT SEAT REMOVAL
Unread post by WELSHVIKING »
I am going to take the front seats out of my xantia tomorrow so i can clean them and try to dry the carpets out . what i need to know is there any particular way you need to remove seats with airbags fitted, i am guessing there will be some type of connection under the seat for the airbag..any advice or instructions would be very much appreciated...thanks Colin
CURRENT CARS:-
2018 CITROEN C4 PICASSO BLUE HDI FEEL 120BHP (WIFES CAR)
2020 CITROEN C3 AIRCROSS 1.2 FLAIR PURETECH 130BHP AUTO (MY CAR)
Dave Burns
Unread post by Dave Burns »
Disconnect the battery (negative first) and wait for fifteen minutes at least, then you can unplug the belt pretensioners under the seats and get stuck in with the torx bits.
Don't forget your radio will lose its code.
Reftit the seats and plug them back in before reconnecting the battery, positive first if you removed both leads.
Dave
James.UK
Unread post by James.UK »
On the ZX the plastic 'rawl plugs' in the floor can turn and undo when you try to take the floor bolts out, if that happens you cant slide the seat forward enough to get at the rear bolts. :shock: So make sure you undo the back ones first, just-in-case :roll: :)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
