remote central locking and alarm on zx
coppertop
Unread post by coppertop »
The remote central locking and alarm on my zx has suddenly stopped working. I have fitted new batteries and when you press the fob the little light operates in the fob but the car won't lock and the alarm wont set. The central locking works fine with the key in the door and the fuses seem ok, it is fuse F4 25 amp according to haynes. Any ideas please :?:
x 1238
Unread post by Peter.N. »
Its probably the remote transmitter itself, they can be a bit fragile. You can have a look inside if you have good eyesight and see if anything has come unsoldered from the circuit board, or , if you get a secondhand one I think you can reprogramme them on the ZX. I have no doubt someone on here will tell you how.
coppertop
thanks Peter, I have tried my spare remote and it still doesn't work. Any more ideas?
x 1238
Ah! Is it an infra red remote? if so the reciever is usually mounted behind the interior light, at least it is on most other Citroens. I dont know if they ever used a radio remote on the ZX, my XM has a radio remote and the reciever is mounted under the glovebox, that would be your next port of call. I suppose the haynes manual doesn't tell you where it is, probably not, that would be to useful!
I suppose that your other remote was working OK before? I have an IR sensitive card that I use for checking TV remotes, but that doesn't help you a lot. I think you can test them by holding them near an ordinary MW radio, you should hear it operate.
I had this problem with my XM and eventually got a secondhand matching key fob and reciever and with mine it was the reciever that was faulty.
coppertop
yes they are ir, it was working fine upto a few weeks ago and it just packed in, so you are probably correct that its the receiver( i have just spent the last 3 hours trawling the old postings).
So my next question is can I just get a second hand receiver and re programme the plip or do I have to have the matching plip with the receiver?
x 1238
I think you can reprogramme the plip but I am afraid I dont know how, I am sure someone on here will tell you. There is a string about it on here somwhere.
