Hi Gang,
I've got an R reg 2L CT Turbo auto XM which for the most part drives well (odd shimmy at speed, but that's for another post), but the thing that's getting on my wick is a hyperactive indicator relay (i think)...
Symptoms:
Sometimes the indicator relay clicks hyperactively when not indicating... (there are no external signs - ie the lights don't flash) and when i indicate the clicking settles down to its normal speed tick tick tick... but when i cancel the indicator the clicking speeds up...
This is not a constant ie. it doesn't always happen, and it doesn't seem to affect anything but it is rather annoying, and i expect that it can only get worse!
Any thoughts?
OLIx
XM and some very odd clicking....
- x 1238
Clogzz
- x 40
NiSk
Well known problem - the contacts on the indicator switch wear and leave deposits of conducting material that then gives intermittent operation when you don't need it. If you take the indicator assembly apart and blow out all the conductive dust and then reassemble it, it will work for as long as before again until it starts doing the same thing again!
//NiSk
//NiSk
oli_25_uk
- x 1238
zzf00l
