WHEEL SIZE FOR XANTIA
WELSHVIKING
x 4
Unread post by WELSHVIKING »
Hi, Can anyone tell me the wheel size for a xantia hdi sx " w" reg ?
thanks Colin
andmcit
x 30
Re: WHEEL SIZE FOR XANTIA
Unread post by andmcit »
WELSHVIKING wrote:Hi, Can anyone tell me the wheel size for a xantia hdi sx " w" reg ?
thanks Colin
Guess it depends on the wheels fitted! 14" on steels & 15" alloys. The alloys run 195 55 15 and I've seen the steels with anything from 165 to 185 with varying 55-60 section. Then of course you can have all manner of aftermarket alloys & begged/borrowed one's off Fords Peugeots etc, aren't they 4x 108PCD...
Think the SX will be sitting on 14" steels even on an W plate.
All the best,
Andrew
np
Unread post by np »
15" wheels.On the older Xantias,the tyre size was mainly 185/65/15,or for the pertrol turbo(?) & 2.1 TD it was 205/60/15.I think there may have been a few more size tyres,but those 2 were the main size.But yours should have 15" wheels with wheel trims. :)
53`406 est SE Hdi 140,110k
np
Unread post by np »
[/quote]
Guess it depends on the wheels fitted! 14" on steels & 15" alloys. [/quote]
Early Xantias had 14" steels,15" alloys,then from N/P reg,or all estates had 15" steels or alloys. :)
andmcit
x 30
np wrote:15" wheels.On the older Xantias,the tyre size was mainly 185/65/15,or for the pertrol turbo(?) & 2.1 TD it was 205/60/15.I think there may have been a few more size tyres,but those 2 were the main size.But yours should have 15" wheels with wheel trims. :)
Must admit, I've not had to do anything YET on my R reg facelift 2.0 16v Xant SX estate, but no doubt it has steels so probably HAS 15" ones on it!!
All the best,
Andrew
np
Unread post by np »
All the old style "mk 1" Xantias i`ve seen,SX & VSX had 15" alloys the same as mine.The later "mk 2" facelift cars i`ve seen,its only the Exclusives with alloys.All the SX`s i`ve seen have wheel trims,the same style as the LX`s etc.It would apeer that Citroen decided to make the alloys a cost option on the face lift SX models,but they seemed to be standard fit on older SX`s :? .
Penny pinching i supose! :)
Cheers,Neil
andmcit
x 30
np wrote:All the old style "mk 1" Xantias i`ve seen,SX & VSX had 15" alloys the same as mine.The later "mk 2" facelift cars i`ve seen,its only the Exclusives with alloys.All the SX`s i`ve seen have wheel trims,the same style as the LX`s etc.It would apeer that Citroen decided to make the alloys a cost option on the face lift SX models,but they seemed to be standard fit on older SX`s :? .
Cheers,Neil
Posh Xantiae round your way then Neil!! :wink:
Round here I ONLY EVER see alloys on VSX's!!
Guess they would have been an option when new but more likely they'll have been ebayed for 20quid by handy owners who fit them on instead of the dimple edged bolt through wheeltrims that were shared with the LX's.
All the best,
Andrew
zzf00l
Unread post by zzf00l »
Just to add to the confusion... earlier Xantias had 'reduced width' spare steels to fit in the under boot cage.... later ones are full size.
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
THELABMAN
Unread post by THELABMAN »
My last Xantia was a 1.9.TD SX and registered if memory serves me early 95 it was an N plate and ran on 185 x 65 x 14 tyres on steel wheels, later that year just before the P plate came out wheels changed to 15" and 195 x 55 x 15 tyres. My current Xantia is a 1.9TD sensation running on 185 x 65 x 15 tyres on non-standard alloys but the tyres are the correct size as listed on the sticker on door shut, hope this helps a little.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
nick
Unread post by nick »
I've got a PDF file of a Xantia brochure from Oct 2000. By that stage the only models available were the LX & SX with either an 1.8i 16V petrol or an HDi 110 diesel.
It gives the petrol as having 185/65 15 tyres, and the HDi diesel as 205/60 15 (both with steel wheels).
p20
Unread post by p20 »
I was told the hdi90 had 185/60/15 and the hdi110 had 205/60/15. I can confirm the 110 as thats what mine wears.
307SW HDi 110
WELSHVIKING
x 4
thanks
205x60x15...had 2 fitted...thanks again
CURRENT CARS:-
2018 CITROEN C4 PICASSO BLUE HDI FEEL 120BHP (WIFES CAR)
2020 CITROEN C3 AIRCROSS 1.2 FLAIR PURETECH 130BHP AUTO (MY CAR)
