Hi
A few questions (again!)
1, I have a knocking on the front end again - only 12 months ago the ball joint was changed, and in feb this year i had a new strut and anti roll bar link fitted to pass the mot. The anti roll bar link has split rubber on it - could this be the cause of the knocking?
2, Should i get anything else changed when I get the cambelt done in a couple of weeks?
3, Is it easy to take the buimper off to change the sidelights as they are both out?
I know this is a pain of a car, and with no bol its hard for me.
Many Thanks in advance
John
Citroen Xsara 2001
It could well be an anti-link bar that has sadly failed very early on (it can happen!), however one other thing that i could suggest just from a personal experience and i know that someone else suffered the same and he indeed had the same problem.
My Temptation ZX got a slight knocking on it and within the 3 months of ownership my mum had of it afterwards it had gotten a whole lot worse, very very worryingly bad, turned out to be two worn bushes on the gearbox....sorted!
Just another one to be considered that causes knocking....but this started off a little and then got really really bad!
Volkswagen Golf 59' 1.6TD S
