Xantia Smelly A/C or Heating System
mattpc
When I jump in the Xantia and switch it on at the moment the heating system seems to blast some really smelly air at me. Doesn't matter if the aircon is on or not. It's not the failing heater matrix smell- I do get that a little bit as well but the carpet is not damp in the passenger footwell and it's not losing any coolant. Also the fan only seems to either work on full power or not at all and the heating system seems to work on a cold or hot basis. Furthest left setting is cold and one notch further to the right and all subsequent notches are hot. Oh and the ambient temp sensor isn't working. The car is a 6 year old HDI 110 SX 141k
Mandrake
- x 694
Re: Xantia Smelly A/C or Heating System
A dirty/clogged pollen filter which is growing all kinds of bacterial wildlife inside it perhaps ?mattpc wrote:When I jump in the Xantia and switch it on at the moment the heating system seems to blast some really smelly air at me. Doesn't matter if the aircon is on or not. It's not the failing heater matrix smell- I do get that a little bit as well but the carpet is not damp in the passenger footwell and it's not losing any coolant. Also the fan only seems to either work on full power or not at all and the heating system seems to work on a cold or hot basis. Furthest left setting is cold and one notch further to the right and all subsequent notches are hot. Oh and the ambient temp sensor isn't working. The car is a 6 year old HDI 110 SX 141k
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
mattpc
Clogzz
- x 40
London luke
p20
It could be a blocked aircon drain. Thats happened with mine. Although i'm not using the aircon at the moment so gave up looking for the damn thing. You can buy aircon system cleaner, which works pretty well. Set it away with the aircon on full and on recirculation for 10minutes and your system should be bacteria free. The car also smells like it just been valeted. Try finding the drain first though, then you can tell me where it is.
307SW HDi 110
NiSk
mattpc
London luke
JohnT
totters
I don't have a solution, but the same problem. I've got a 97 xantia whith that problem of a strange smell when the heater is turnrd on to hot. It sort of smells like "deep heat", the stuff for spraying onto pulled mustles. Someone else told me it might be a coolant smell. didn't look yet, a bit puzzeled ya know. please reply with any suggestions.
Clogzz
- x 40
f00lzz
Tried removing my filter on both cars...... still can't get get that damn cover to slide off despite all help/diagrams etc off you guys.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Clogzz
- x 40
Hi f00lzz,
Maybe try with a lamp and mirror to properly see under there.
Probably that there are still screws to hold the sliding cover in place.
The cover is on the floor in this photo, and the catches look fairly substantial.
You may need a sturdy screwdriver to grab into the ridging in the plastic.
Or even use a sort of drift to lightly tap outwards with a hammer.
The old posts still apply.
I’ll dig them up if you like.
Regards,
Terry.
f00lzz
Believe me! I have all the old posts
Checked for screws (good tip with the mirror) I'll get my big hammer out and give it a whack!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
