1.5 D AX difficult to start
Jshodgson
Unread post by Jshodgson »
My brother has a 1.5D AX (N) and during the recent cold weather it has started to struggle to start. It takes 3 attempts before starting. The glow plugs are fine but the car had to be fitted with a new fuel filter as the previous owner had bypassed the filter when a hose broke.
We've stuck some redex in it, any other ideas?
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
fatboyslimfast
Unread post by fatboyslimfast »
Does the engine sound as if it has no compression? Incorrect valve clearances are common on this engine causing poor starting. Its not too bad to check them but we use a special compresion tool to get the shims out.
jeremy
Unread post by jeremy »
Is air getting in the fuel? sometimes use of the hand primer will improve things and this probably meand air. Check everything very carefully. If you have a Bosch pump the leakoff pipes should be checked as well, but those on a Roto-diesel pump make no difference.
It may help to replace the last feed pipe to the pump with plastic so you can see the bubbles (and know when you have found the source).
have you got the black plastic filter/heat exchanger? If so a thermostat at the bottom can leak. There is a detailed post on this problem on this board.
jeremy
x 1238
Unread post by Peter.N. »
What is the condition of the battery, is it turning over as quickly as it used to?
Jshodgson
It has a brand new battery.
JohnT
Unread post by JohnT »
You probably have the right new battery, but it should have around 495 amps plus power. I have seen many starting problems with low amp batteries being fitted to economise and they do not have the necessary cranking power. Perhaps this is an obvious suggestion but it does catch people out.
Cheers!
John
