Does anyone know / have any more info on this beast?
http://www.cardomain.com/ride/2145420
V6, 3.0, ZX.....OHYESPLEASE!
3.0 V6 ZX!
Ian Fearn
Sl4yer
He's posted on here asking for a meet:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=16477
That is a REALLY good mod though...
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
p20
rossnunn
Toddman
BX brakes
I could be wrong but I was lead to beleive the only issue was the type of rubber used in the seals, i.e. LHM rubber and std rubber so I would expect some cars use the same calipers as the BX but with std rubber seals.
Just a thought
Cheers
Luke
Just a thought
Cheers
Luke
Bx 16v Phase2 - White 1989 - 0-60mph 6.8s 1/4mile 15.2s
Bx 16v Phase2 - silver 190
rossnunn
jeremy
- x 3
I'm sure I've seen calipers very similar to those on the front of a BX on the rear of a Golf GTi. I agree - a competent brake specialist can probably supply the appropriate seals - if indeed there is any difference.
Looks like the gearbox that came with the engine was used. Remote servo would solve many problems - Juguar used to put them underneath the back seats in the chassis on the Mk V11 - IX models - where predictably they corroded beautifully.
jeremy
cornishbx16v
you will also see the bx calipers on the rear of 205/309 1.9 8v gti's too! not sure if they are the same width but they lok the same to me!
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16valve.co.uk
http://timmos.mysite.wanadoo-members.co.uk/
VisaGTi16v
yes, waste of time. Don't get me wrong, great that hes done it, unique etc but it wouldnt go round corners! The v6 engine is over 70kg heavier than the 1.9 xu9j4 as far as I remember! One of them on throttle bodies, light head work and with fast road cams will result in the same power and a lot better handling.
Darren
2000 Xsara VTS
1986 Visa GTi 1.9 16v
2000 Xsara VTS
rossnunn
VisaGTi16v
on the road perhaps, take it somewhere where you could drive it properly and there would be a massive difference between his and a identically powered 1.9, around a track for example. You could overcome some of it with decent suspension but still tricky. No wonder he has put such big brakes on
This reminds me that my friend used to have fantasies about an AX V6 sigh
Darren
2000 Xsara VTS
2000 Xsara VTS
rossnunn
jeremy
- x 3
