Hello all!
Ive found you at last,my wife has been bought a 93 1.6i xantia as a birthday present by her mother oh joy! Im fairly well experienced in mechanical ways but im a bit green as regards to hydraulic suspension/steering/brakes linked,and the xantia has a few problems in that it takes a while to raise when cold and seems to click from the pump? every 2 seconds when running it seems and the suspension seems to move up and down when it feels like it at times? and the headlights are absolutely terrible on dipped beam,you get the same amount of light as the sidelights it seems,any clues guys!?
Thanks in anticipation and im glad ive found the forum!
Hello all!
Bigjoe
Hello all!
Im out there somewhere!
Xantia 1.6i LX (i know but i had to start somewhere!)
JohnT
I suggest you use the search button for the suspension problems, these subjects have been covered extensively by more knowledgeable people than me.. A word of warning though, the car can collapse in a split second when pressure is lost, so follow all the safety rules. Check the resovoir level first. A 93 model will loose height soon after the engine stops. (No anti-sink valve?) Overnight the car should raise in about twenty five seconds or earlier, its hardly an ideal get away car for a bank robber!
Try doing the Citrobics, raise and lower the car at least 7 times to ensure any crud is sent via the return system to the filter.
Cheers!
John
John
Homer
- x 16
It really shouldn't. And it's nothing to do with anti sink valves.JohnT wrote:A word of warning though, the car can collapse in a split second when pressure is lost,
The height correctors should prevent fluid leaving the struts at any kind of speed. It will sink but not rapidly.
You will however lose all braking force shortly after a loss of pressure so it is best to stop ASAP for that reason.
- x 1238
mike_zr7
I agree with Peter, the first thing you should do is change the accumulator sphere. The pump should only tick once every 30 seconds or more. I changed the accumulator sphere on my xantia recently. The accumulator sphere is at the front of the engine. Do a search for accumulator and you should find several posts on how to change it. I had to resort to a hammer and chisel remove the accumulator shere on my xantia. Dont know about the problem with your headlights, may be alternator related.
1996 Xantia 1.9TD 78.000 miles, not yet run in
mezuk04
jeremy
The pump/accumulator should cycle at intevals of 30 seconds or more. There are 2 main reasons for frequent cycling - flat accumulator and leaky regulator non-return valve. The accumulator can be tested by raising the car to normal height, turning off the engine and sitting in the boot. If the accumulator is sound the car will sink quite a long way (they are very soft) and after about 30 seconds rise to its original height. Another test is to raise the car fully - the ticking should slow as the suspension spheres are functioning as accumulators.
joe - it sounds as though yours has failed - a new one is about £20 from GSF or Eurocarparts.
Instructions for re-seating the non-return valve have been given by me may times on this forum.
Lights on early Xantias are always a problem. probably a partial cure is to provide a direct fused supply from the battery, using the existing supply to operate a relay to control it. First however check the all connections are clean and in particular that the earth connections are good. (you could try a lead attached to the battery negative terminal, and touch it on the appropriate part of the lamp (earthed) and see if the beam gets brighter.)
jeremy
FrenchLeave
Mandrake
- x 694
The word "should" being the operative word here. You can never be too careful when your safety is at stake.Homer wrote:It really shouldn't. And it's nothing to do with anti sink valves.JohnT wrote:A word of warning though, the car can collapse in a split second when pressure is lost,
There are a number of theoretical faults that could occur that would cause the car to drop more rapidly than you can get out from under it.
For example if the suspension was set fully up and the manual height override linkage somehow came loose or broke, once the car started dropping visibly you would only have a couple of seconds to get out until you were squashed.
Other possibilities would be hydractive valves unexpectedly opening (which can jolt the height VERY suddenly either higher or lower depending on whether the hydractive sphere had lower or higher pressure beforehand) or a pipe bursting, etc....
Citroen hydraulics are pretty reliable all things considered, (after all you are driving on them on the road all the time) but whenever working on the car you should always be thinking "if the suspension suddenly fell now, would I be hurt?"
If you have your arms in the wheel arch above the wheels or your body under the car without ramps to give you clearance then the answer is yes....
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
dnsey
- x 19
