picasso HDI cat pipe snapped.HELP!!!
bikemad650
Has anyone any idea how much the front pipe is inc cat and a flexible as it all seems to be in one, also is it main dealer only or can i get one from somewhere else cheaper. cheers Ian 2000 hdi picasso 2.0
NiSk
Modern cars usually come with fully welded exhaust systems from the factory - when a part needs replacement you use an angle grinder and cut it at the appropriate place and slot in the replacement section. On the other hand if your'e going to keep the car for a reasonable time it would be worth fitting a stainless system.
//NiSk
//NiSk
