I hope you can help me on this one,be greatful for your replies.
In the last week or so I've noticed that my Xantia rear suspension is 'creaking' when I get into and get out of the vehicle.Now I'm not a heavy person,far from it.Upon noticing this I got under the rear of the car when set to maximum height and lubricated the infamous 'white' plastic link(which I also did a few months ago) near the height corrector thinking this was sticking.This didnt seem to make any difference.I also noticed the rear ride height is a little lower than usual on normal setting (rear wheel arch just above rear tyre).
Driving the car today, the road near me has a rather sharp dip and incline
giving the car's rear suspension a chance to 'bottom' out upon which the rear suspension gave out that so called 'creaking' sound again-slightly worrying for me!!
My question to to you all,what might be happening or not happening and what could be the possible solution?
Are my rear suspension arms possibly on their way out(bearings) the car has only covered 102k miles.
Also, recently,I dont know if this is related or not but my 'stop' light and lhm warning lamp on the dashboard stay illuminated for approxiamately 4 seconds when starting the car from cold(this has never happened before).There's plenty of nice green lhm fluid in the the reservoir and the pressure regulator 'clicks' are of normal duration between clicks.
Does the cold weather affect the viscosity of the lhm and therefore somehow affect the hydraulic system in a way that gives all sorts of problems????
P.S This is the first time I've owned a Xantia through the winter period.
1994 1.9sx TD ,no anti sink sphere's,no air con.
Thanks in advance to any replies.
Stevie
